joelyn wrote:
Will check them, I know I replaced them about 3 years ago but like I say the sun out here and 120 deg, temps destroys everything...put solar street lights on the house back in may and by aug they were all destroyed, one even fell off the mounting pole when the sun just made the plastic housing so brittle that it just fell off...
ty
and when you do find and fix the leak, make sure you are coating all the exposed non metallic parts for UV protection. You can use 303 as a general coating that works good on everything or something like TriNova that is excellent for rubber type parts. Unlike hard plastics, the flex parts need that extra protection to keep them from getting brittle and stay flexible.
