dougrainer
Mar 12, 2020Nomad
The VERY SMALL (microscopic) possible leak in the rubber parts of the closed LP system WILL leak out over time. BUT, while the LP has leaked out, there is no way for AIR to then migrate IN. It took pressure to force the LP thru the microscopic voids in the seals. So, when you find the LP has dissipated from storage, when you open the tank valve, all you are doing is filling the lines with LP vapor and basically going down an empty pipe. Doug
Having RV issues? Connect with others who have been in your shoes.24,243 PostsLatest Activity: May 11, 2025
