trailgranny50
Oct 30, 2015Explorer
All the grill has is a snap small L shaped valve. I just replaced it as grill company said they'd had problems with it. Problem persists. The gas line had been teed in after the regulator, as was the case with the camper it initially came with. There is gas up to where the short hose plugs in, none after. To test the grill at higher pressure would take changing the end on the hose I use for my Coleman to a quick disconnect, then I'd need an adaptor for that or cut more hose and redo it after the check back to what it was. Expensive and at this point a real pain. Thinking about just trashing this brand new but useless grill,change out the end on the already installed hose to match Coleman and hook up the extended line to tank before regulator and just use it, as it actually works. Just thought the quick disconnect more convenient, but only if it works.
