matthfam's avatar
matthfam
Propane Refills
After reading on this site about what a propane tank should weigh when empty/full, I decided I should weigh mine. I had used one tank only with the other one shut off ... The "full" tank weighed in at 44 lbs. the used one at 35.5 lbs. While it makes sense that I used about 8-9 lbs from the tank I was using, it makes no sense that they weighed 44 lbs when full. I was ripped off.
There could be a small difference to the 55 lbs supposed weight when full, but 11 lbs? They advertise as the cheapest propane in town. Not cheap at all! Take a scale with you when refilling!
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 19, 2025
