monrcar's avatar
monrcar
Propane Regulator leaking on Street Side
Hi,
My Cougar 5th Wheel (6 years old) has a stand alone 18psi (GR-618) red regulator on the street side propane bottle, which enters a pipe that crosses the front to the curb side. On the curb side is the standard switching regulator. I put the street side bottle on service and got a major leak from the vent hole on the GR-618 regulator. (Blowing propane). I read about the 2nd regulator on this "closed" topic:
(http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/23537608)
I've also read on two other forums persons have had the same leak. (Google search: LP GR-618 LP regulator leak) But very limited additional information.
I'm concerned this may be a common problem with these 2nd regulators. I'm thinking of just capping the pipe from the street side bottle and physically swapping bottles when needed rather than risk an un-controlled propane leak.
Any input appreciated. And have others experienced this problem?
edit: Here is a picture of the leaking regulator. Leaks at the vent hole below the "S" in "PSI"..
  • wa8yxm wrote:
    To the person who mentioned the not understanding the purpose of the single stage regulator
    There are basically 2.1 types of regulator systems I have seen (this is the .1)
    Single stage take gas from a variable pressure of around 100 PSI (can be 50 or 200) to a pressure of roughly 0.5 PSI in one jump, That's a lot to expect of a regulator. (O.5 PSI is about the pressure needed to hold 11" of water up, the exact outlet pressure is = to 11" of water least anyone want to argue with my 1/2 PSI round off).
    Thus they came up with the 2 stage, Take it down to about 20-30 in one step, and 1/2 in the second.
    usually the sequence is Tank-line-switchover valve-Stage 1-Stage 2-lines to appliances.
    In this case it's Tank--Stage 1--Valve--Stage 2
    NOTE that there are two tanks and two lines to the valve (And in this system two stage 1's)
    That was me- I was actually wondering WHY there's a regulator on the offside tank plus a double autochangeover (two-stage?) regulator at the "main" tank. Most dual tank setups have only the latter.
    Or did I get that completely wrong?
    READ my post. It is to prevent HI pressure gas from going from one side of the RV to the other. IF you have a break in the supply line from the RED regulator side to the other side which has the regular LP regulator, it will be low pressure and not as much as a danger. Yes, leaking LP is a danger, but better to have low pressure smaller leak than a HI pressure leak. The reason to have a 2 stage regulator is you get a better constant 11.5 inches pressure. A Single stage can possibly have low pressure fluctuations. You will see single stage on Gas Grills and such as that type appliance can handle fluctuations and the LP regulator is only handling that one appliance. Doug
  • Old topic I know. Just ran into this problem today. My question is why is the propane not regulated to 30 pounds(in my case with the GR 630 on the street side) on both sides? The curb side tank goes directly into the switching regulator with no pressure drop.
    distance.
    RVIA adopts NFPA which calls for regulation (min of 30 psi) within 60".
  • Still doesn't make sense. The unregulated tank is 12" from switching regulator and it's pressure is not decreased prior to entry to the switching regulator. In other words, far tank is regulated and enters switching regulator at 30 psi. Close tank is not regulated and enters switching regulator at tank pressure (around 100 psi depending on temp).
    The switching regulator is two stage and will handle 30 psi or 100 psi just fine on each side with no effect on operation.
    Safety calls for no longer than 5' hose at full tank pressure so what is the issue?
    If you want a 30 psi regulator on both that is fine but redundant.
  • Ok, I get it now. Guess I just didn't understand Red31's reply. Thanks for clearing it up.
  • The reason for the regulator is that under some conditions liquid could recondense in the crossover pipe if it is at tank pressure. Lowering that to the 30 psi range keeps that from happening.
  • Posted By: Chris Bryant on 01/18/16 05:38am
    There you go again - - confusing the issue with fact. :B
    Art.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
