joebedford's avatar
joebedford
Nomad II
Feb 08, 2023
Propane smell inside oven
There's a thread which is very useful not not quite applicable to my case: "Propane smell inside trailer...how to best diagnose?"
There is a slight propane smell inside the oven when the pilot is lit but none anywhere when the pilot is off.
What should I look for?
  • enblethen wrote:
    Why are you leaving oven pilot on when not backing or broiling?
    I do that. Is that a problem?
  • Look at the end of the pilot tube. Many have a small "deflector" it could have been hit so the pilot is not burning all the propane.
  • If no one else has a good answer, this might be a question for youtube.
  • It smells with just the pilot going (though I think it also smells when the pilot is on and burner tube is lit).
  • joebedford wrote:
    As long as the pilot is lit, the smell remains; it goes away after the pilot is turned off.
    Is the pilot the only thing lit, or are you cooking in the oven?
  • There is no smell when the pilot is first lit; it accumulates after 2-3 minutes. As long as the pilot is lit, the smell remains; it goes away after the pilot is turned off.
    There is no smell at the valve ever.
  • ^Agree... also with pilot burning, a leak inside oven, would also ignite, if there was one.
    In any case, best not put nose/head inside oven with, or without pilot burning.
    Jerry
  • It could be simply the slight bit that comes out before it's lit.
Having RV issues? Connect with others who have been in your shoes.24,322 PostsLatest Activity: Jun 17, 2022
