mattyj
Dec 19, 2019Explorer
Propane smell
Hi, I am Puzzled I removed the regulator and both horizontal lpg tanks and the camper still smells like propane! Does anybody know what could possibly be the cause of this? Thanks,Lou
NEOK wrote:In addition to the above , I have noticed the odor is stronger as the bottles are nearing empty . It could also be the remaining gas and odorant in the lines after removing the regulator .
The odorant put in propane so you can smell the gas is very strong and will tend to hang around anything it is close to such as your propane storage compartment.
Old-Biscuit wrote:. I Removed the regulator and the two tanks to try process of elimination because of the smell of propane, I will try airing everything out thanks
With reg and cyclinders completely removed the smell will go away ......some propane may leak from the open line from where reg connected to main lp piping.
Not sure why you removed the reg/cylinders but if leaving them out permanently then you should cap/plug the open line where reg was and another open line
