ret_usn's avatar
ret_usn
Propane smell
I can smell propane slight odor, It is coming from the furnace vent outside. I have checked all tank connections and all fittings including furnace gas fitting and regulator with a soap solution. No odor in the camper and only around the furnace vent outside. I just purchased this unit a couple of weeks ago and finally tracked the odor down. Alarm does not go off inside and there is no smell inside. I did lite the furnace to check operation. I also know the tank that is in use is almost empty. Not sure if this is normal or maybe furnace regulator is leaking a small amount into furnace. When I tried it cycle and ignition was normal. Any help or ideas appreciated.
