I can smell propane slight odor, It is coming from the furnace vent outside. I have checked all tank connections and all fittings including furnace gas fitting and regulator with a soap solution. No o...
Ken I should have read your post more thoroughly as I did remove the furnace. Now I know better. It was not that hard. I had no idea how to remove the gas valve until I got it out and it really would have been easier to remove the gas valve and not remove the furnace. OH well at 78yo I am still learning.I will wait til I install the valve before putting it back in. The good side I found 2 vents with holes torn in them. easy fix with AC foil tape.Thanks for the help
