I have 2 burner stove , you push in the knob & turn, then push the igniter, burner lights , hold knob in for a few seconds then let go ,the burner should stay lit. No matter what I do it goes out . Th...
What is the brand and model of the stovetop? I know some European models have a thermocouple safety for the burners, but those will be metric threads. You can test a thermocouple by measuring the voltage when heated between center and outside. Most should be minimum of 15 millivolts, with double that normally.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
