Robin1953
Feb 08, 2015Explorer
rwbradley wrote:Clicky
Install the T after the RV regulator, than do this mod to remove the Regulator on the BabyQ and add a quick connect on the BabyQ. The problem with your 2nd scenario is you are double regulated causing not enough gas flow to the burner.
https://dl.dropboxusercontent.com/u/50969659/weberq.jpg I got the quick connects from my local RV dealer and the other gas fittings and gas tape from Lowes in the Gas Fittings section.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
