YamaDooed
Feb 08, 2015Explorer
If you bought a 10' hose from Weber or Mr Heater.I've found the schrader valve on the end of the hose does not get depressed enough for adequate flow and the grill either doesn't light or only goes to about 350deg. The fix for me was to use a tire valve tool and remove the valve completly from the hose. You can also just unscrew it a half or full turn and it will help with the flow problem.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
