Old-Biscuit
Mar 22, 2014Explorer III
The following is from 'propane101.com'
Position of LP Gas Cylinders In Storage
Propane cylinders should always be positioned so that their relief valve is in direct communication with the vapor space of the container. Cylinders that are stored vertically upright will have the relief valve communicating with vapor space. Regarding the cylinder relief valve, it is important to keep the safety relief valve pointed away from anything that escaping propane could come in contact with possibly causing a fire or accident. If cylinders are stored improperly, such as on their side with the relief valve in contact with propane liquid and the safety relief valve opens for any reason, liquid will be escaping instead of vapor posing a much greater danger. In short, be sure the relief valve is communicating with the vapor space of the tank. All consumer propane cylinders should be stored vertically upright in all circumstances.
A 'vertical' propane cylinder should always be vertical......filling, in use, transporting, storage
Not everyone does........you decide if risk/benefit is worth it.
Why not secure it in bed of truck?
