D_E_Bishop
Mar 22, 2014Explorer
Rickhuntfish, If you use a high pressure fitting instead of trying to use a low pressure QD, you may find it takes about 30 seconds longer to hook up and disconnect the hose and you won't have to remove and replace the BabyQ when you switch from S&B to Rv and back. Beside the whole setup for HP is cheaper than the LP setup.
