- wgriswoldExplorerposted accidently
- AlmotExplorer IIIIf it's partially empty, you should be alright if you keep it partially tilted. It won't be a recommended or 100% safe position, but safer than horizontal because the gas won't flood the valve at the top.
With 20lb tank being almost as high as it is wide, I don't even understand the question. If the 5-er storage space isn't high enough, put it in your truck upright.
About safety... I remember Mexicans delivering 66 lbs cylinder to the camp. The cylinders were transported vertically on the flatbed truck, to please the authorities. Having arrived on the camp, they threw it down from the truck - not lowered, but threw - and one of them rolled it to my rig, kicking with his feet. Horizontally. - BFL13Explorer IIYes, only have one regulator at a time.
- Reddog1Explorer IISafety wise, does it really make any difference how big the cylinder is when carried inside a passenger vehicle? Be it a 20 or 30 pound cylinder, it is enough gas to blow you away. Personally, I sometimes carry a 20 pound strapped in the cab. I am more concerned with it bouncing around in case of an accident, than any other reason.
I am not familiar with the BabyQ, but I do have several other grills I use. I have a quick disconnect to connect to my Camper and a 12-foot hose. It requires no modification to my grills for connection. I have had it several years, and never used it. What I do not know, is if I will have issues with the Camper regulator and grill regulator both connected. As for connecting the grills to the camper, I use a different hose (without quick disconnect) from tank to grill.
Wayne - Dusty_RExplorer
RVnRobin wrote:
BFL13 wrote:
UUUMMM...:h In the cab with you? Looks like another legal/code question.
I take a 30lb tank for a refill sitting on the front passenger seat of the truck, on a towel or pad so it doesn't cut the leather, strapped in by the seat belt. It is supposed to be vertical, so that's how I do it.
Last I knew only a 20lb. is allowed to be carried inside a passenger vehicle.
Dusty - RVnRobinExplorer
I take a 30lb tank for a refill sitting on the front passenger seat of the truck, on a towel or pad so it doesn't cut the leather, strapped in by the seat belt. It is supposed to be vertical, so that's how I do it. - Bill_SatelliteExplorer II
Rickhuntfish wrote:
Can I transport a 20lb propane tank on its side in my 5th wheel basement? I know I will have to secure it from rolling around, but the height with it standing up is the issue I have.
No! - BFL13Explorer III take a 30lb tank for a refill sitting on the front passenger seat of the truck, on a towel or pad so it doesn't cut the leather, strapped in by the seat belt. It is supposed to be vertical, so that's how I do it.
(cost was back to $29 here lately, but was briefly up to $33 last month with all the fuss in the States on propane cost that was going on back then) - D_E_BishopExplorerRickhuntfish, If you use a high pressure fitting instead of trying to use a low pressure QD, you may find it takes about 30 seconds longer to hook up and disconnect the hose and you won't have to remove and replace the BabyQ when you switch from S&B to Rv and back. Beside the whole setup for HP is cheaper than the LP setup.
- down_homeExplorer IIThey make a cradle or stand that holds 20 lb tanks upright for transport. They are usually green and made of plastic. I might want to screw it down because a full 20 lb tank or even empty has a lot of energy when you hit the brakes or accelerate. I've seen them at Ace and perhaps at CW but not lately. Anyplace that sells the tanks should stock them or maybe not.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
