- Cummins12V98Explorer IIII always leave my inner tank CLOSED. Outer runs out I simply switch to inner and then within a day or two get the outer filled then close inner and open outer. As time goes on after several times filling I remove the inner tank and place the full tank in the rear. NEVER run out using this method.
- Dutch_12078Explorer IIIFor those having trouble replacing a Mopeka sensor after a cylinder refill, after I had my sensors in the "sweet spot", I outlined them with a permanent marker. Makes replacing them in the right spot really easy.
- wa8yxmExplorer III
valhalla360 wrote:
wa8yxm wrote:
There are 4 types of propane tank level indicators.
The most common is some kind of RED/Green indicator.. IT works well but.. GREEN means "Tank not empty" red means "Empty" there is only about 10 seconds of in between.. if the tank is 1% full.. it's not empty
Assuming you run a 2 tank system and fill your empties within a week or so, RED means you are at 50%.
Well true. At home growing up we had a multi tank system one tank was always closed so that if we hit red on both sides.> We opened the spare and still had propane for the water heater and stove.
My sister after a lightening strike "There's a fire in the Oven There's a fire in the Oven" me (As I responded "Isn't that how it works?" Then "Where's the baking soda?
I hit the Gas control Solenoid with a bit of Baking soda.. (The lightening strike ignighted the insulation (outer only) and fire out (Well the cooking fire still responded to control but the electrical fire out) Baking soda is a marvelous fire extingushier. - toedtoesExplorer IIII agree with Lantley for the most part.
I normally check my tank levels as I'm preparing for a trip - along with the fresh and grey water tank levels and battery charges - and fill if either are low.
As I tend to camp away from everything, having to fill a propane tank mid-trip may mean a 1-2 hour drive for no other reason. Why bother if I can simply check a couple gauges before the trip and plan ahead.
I also do not have an auto changer, so if I am suddenly without propane, I just manually switch to the second tank.
I you want an even simpler visual, get a plastic slap bracelet. When one tank goes empty, slap the bracelet on its handle and switch to the second tank. Now you know which one to fill before the next trip. - fj12ryderExplorer IIII figure I should be smart enough to check levels on occasion, and therefore use the auto switch-over. Getting up in the middle of the night to switch tanks, when the auto switch-over will do it for me just seems silly. And it's almost guaranteed that the tank will run out when it's most inconvenient. Some things just work, and the auto change-over is one of them. Never had a problem in over 15 years.
- ktmrfsExplorer II
Lantley wrote:
THe whole running out of LP issue is overblown. There is no need to constantly monitor or check your LP level.
Leave one tank on and one tank off. When the on tank runs out simply switch the full tank and refill empty tank.
Worst case scenario is tank runs empty in the middle of the night and you wake up cold! I only use my furnace as supplemental back up heat and heat primarily with space heaters. Its been quite a few years since I have run out of lp in the middle of the night. typically I discover the fridge won't work on gas and switch tanks.
If you allow auto switchover system to work as designed the tanks may switch without you realizing it, potentially leaving you with 2 empty tanks and no lp.
While our usage is different most Rv'ers don't use lots of lp to warrant all the gauges and monitoring.
I typiaclly refill my tanks at some point once a year, with that in mind there is no need for me to monitor tanks weekly or even monthly.Just let the tank run out and manually switch it when necessary.
I guess where and when one camps has an influence on LP tank level checking need. this last week temps were down in the mid 30's at night and we went almost through one 30lb tank in 7 days with the furnace turned on when we got up. Even a month ago it was cold enough at night and early morning that in a 10 day campout we went through one tank before the camp trip ended. We dry camp 90% of the time so propane gets used frequently for the fridge, (not much) water heater and furnace.
I use the auto changeover system on my regulator but it is also an older marshall regulator system that has a remote display in the trailer that flashes when the regulator does a changeover. At least with that I do know when a tank is empty. Between that and the mopeka system everything is covered. - Tyler0215ExplorerLantley has it right.
- LantleyNomadTHe whole running out of LP issue is overblown. There is no need to constantly monitor or check your LP level.
I typiaclly refill my tanks at some point once a year, with that in mind there is no need for me to monitor tanks weekly or even monthly.Just let the tank run out and manually switch it when necessary. - fj12ryderExplorer IIII tried the Dometic wand sensor and had little luck getting it to be consistent. I use the Mopeka sensor on one tank and check it every few days, maybe if I think of it. We have the auto switch-over so mostly don't worry about it. When the switch changes to red, I pull the empty tank and fill it, then put it back in place, and turn the handle on the switch so it's green. Repeat as necessary. We travel when it's cool, but rarely when cold, so we don't go through a lot of propane.
FWIW, I sanded the bottom of the tank before installing the Mopeka sensor, and then taped it to the bottom. Our tank supports are just two bars so they don't interfere with the sensor at all. And it showed a drop in tank level the day after the tanks switched, so it works pretty well.
Having RV issues? Connect with others who have been in your shoes.24,292 PostsLatest Activity: Jul 29, 2025
