Nevrdun's avatar
Nevrdun
Propane Tank level question
My tank level indicator seems to be showing red even though I know both tanks are full or near full. Please see photo. Can anyone tell me what my issue may be? Thank you for any input you may provide.
Click For Full-Size Image.
  • There is normally a black cap that goes over the top of that dome.
    If it was there then you would only see the green at the bottom, then when the tank you are running from goes empty the red would drop down into view.
    You are missing a piece, go to your local rv parts store and look at new regulators.
  • 1. Those are HORIZONTAL tanks.
    2. The level gauge is a FLOAT designed Gauge
    3. Makes NO difference if tank on or off.
    4. REGULATOR REPLACEMENT???????????????????????????????? WHY
    5. Yes, if OVERFULL the gauge may do that
    6. If tank upside down it will do that Rotate 180 degrees and see what happens
    7. Sometimes a float can get "stuck" inside the cylinder. Remove the cylinders MAKE SURE they are really full. Then lay down or rotate 360 degrees a few times to free up stuck float.
    8. This is the BEST and ONLY type level gauge system that always works, as it uses a inside float to gauge fluid level. It is the same design used on ASME motorhome tanks. Doug
  • Nevrdun wrote:
    Thank you. Can you suggest where I would get the regulators?
    Find a good RV shop in your area. You can also just go to Amazon and order them. Just don't go to Camping World for parts or repair.
  • Are you sure it is not over filled? Turn tank off, take line loose and see what direction needle goes. The valves need to be turned on verrry slowly otherwise tank thinks there is a leak.
  • Thank you. Can you suggest where I would get the regulators?
    Buy 2 new regulators. Buy regulators with easy to read RED/Green window indicators.
Having RV issues? Connect with others who have been in your shoes.24,333 PostsLatest Activity: Nov 06, 2025
