GASMAN6674
Jul 08, 2016Explorer
Your fridge is running more in the heat, but mix up a soapy solution of dish soap and water and brush or pour it on all the connections you can reach and look to see if any bubbles grow. If they do you have a leak.Or you can have your local full service LP Gas Dealer run a pressure check on the system for you.
Good Luck
Good Luck
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
