egarant
Oct 13, 2022Nomad
Well I called Shurflo today, hard to find their number, but it's 1-800-834-3218, keep it in your phone.
According to the tech, if you have the 4008 pump, as stated the turn on pressure is not the re-start presure and he didn't know why the manual for the pump doesn't clearly state it.
The turn on pressure for that pump is 38 psi, so the accumulator pressure should be set at 38 psi.
I think someone did come to that same conclusion, but I thought I'd double check.
Cheers,
Mr. E
Cheers,
Mr. E
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
