- Old-BiscuitExplorer III
lawrosa wrote:
Thats how it works in residential applications. Ive been on 1000's of calls for failed exp tanks on closed loops systems. On arrival the relief valve of water heaters spewing all over the place.
Why would a RV be any different?
Why do you think your relief valve weeps in your RV? Mine does when water is heating..
With air pocket.........pressure increases to roughly 110--115 PSI
(Depends on initial water tamp & density)
T&P Relief Valve OPEN (Spew) at 210*F/150 psi (reset when pressure drops to 125 PSI)
WEEPING is due to loss of that air pocket....water can't be compressed/air can
You can flame me all you want. I have thick skin... Im just bringing up a valid point..
I did fail to realize there is a spring check in the water inlet:E
More so why a accumulator or exp tank is beneficial...
RV Plumbing System is a 'closed loop' AND a small one.
Air Pocket in water heater plays a big part in that system
Just saying........ - sgfryeExplorer
Old-Biscuit wrote:
Hook it at spigot then put on a 'wye' so water regulator controls pressure in both hoses...
*potable one for fresh water usage....in-line filter and just fill fresh water tank and use pump
*garden hose for general purpose usage.....washing down, black tank flush, spraying kids/dogs etc
This is my setup also - imgoin4itExplorerI hook the wye on the faucet, them put the regulator on the side that supplies the hose to the RV. I use the non regulated side of the wye for the hose that I use to flush the tanks. For flushing I want all the pressure I can get.
- wa8yxmExplorer III
enblethen wrote:
I put it at the spigot to somewhat protect the hose.
Though I now use a different method to protect my hose (Turn the spigot off Do not put static pressure on the hose) THe park I'm in has clocked pressure over 120PSI Enough to blow a hose apart. Hence I support the above
Now the issue.. Many Filters restrict flow so you need a higher pressure at the filter.. The hose can take 70 PSI or even 80 usually well but not 120
So if you have a restrictive filter.. Two regulators. good quality jobs like Watts, Zurin or the Valterra Adjustable. I set the spigot to like 6-70 and the filter out at 50.. But I now have a filter that allows better flow so 50 at the spigot when I use city water.
For assorted reasons though I just fill my on board and forget the regulator. Turn it off and don't worry about it . - 12thgenusaExplorer
Dutch_12078 wrote:
I do find the accumulator tank I installed in our RV beneficial in reducing pump starts and the need to re-establish the heater tank's air pocket, but as far as the water heater itself goes in the absence of an accumulator, if the relief valve is weeping when heating, then the air pocket in the tank is gone. Simply draining the tank fully with the relief valve open will re-establish the air pocket as noted in the owners manual trouble shooting section for most. Not all residential systems have an accumulator tank either.
No need to fully drain the tank. Simply turn the pump and/or city water off and open a tap inside to relieve system pressure. Then open the lever on the relief valve until water stops flowing. Release the lever and the air pocket is re-established. - lawrosaExplorer
PRESSURE RELIEF VALVE
The tem perature and pressure relief valve is designed to open if the tem perature
of the water within the heater reaches 210°F, or if the water pressure in the heater
reaches 150 pounds. Recreational vehicle water system s are closed system s and
during the water heating cycle the pressure build-up in the water system will reach
150 pounds. W hen this pressure is reached, the pressure relief valve will open
and water will drip from the valve. This dripping will continue until the pressure is
reduced to below 150 pounds, and the valve closes. This condition is norm al and
does not indicate a defective relief valve.
WARNING! Do not place a valve between the relief valve and the tank. Do
not plug the relief valve under any circumstances.
WATER WEEPING OR DRIPPING FROM PRESSURE
RELIEF VALVE
You m ay experience water weeping or dripping from your water heater’s Pressure
and Tem perature (P & T) Relief Valve when your water heater is operating. W ater
weeping or dripping from the P & T Valve does not always m ean the P & T Valve
is defective. As water is heated, it expands. The water system in a recreational
vehicle is a closed system and does not allow for the expansion of heated water.
W hen the pressure of the water system exceeds the relieving point of the P & T
Valve, the valve will relieve the excess pressure.
Suburban recom m ends that a check valve not be installed directly at the inlet to
the water heater tank. This will increase weeping of the pressure relief valve.
WARNING! Do not remove or plug the relief valve.
One way to reduce the frequency of this occurrence is to m aintain an air pocket
at the top of the water heater tank. This air pocket will form in the tank by design.
However, it will be reduced over time by the everyday use of your water heater.
To replenish this air pocket:
1. Turn off water heater.
2. Turn off cold water supply line.
3. Open a faucet in the RV.
4. Pull out on the handle of the Pressure Relief (P & T) Valve and allow water
to flow from the valve until it stops.
5. Release handle on P & T Valve - it should snap closed.
6. Close faucet and turn on cold water supply; as the tank fills, the air pocket
will develop.
Repeat this procedure as often as needed to reduce the frequency of the weeping
of the P & T Valve. If the weeping persists after following this procedure, you m ay
elect to install an expansion or accum ulator tank in the cold water line between the
tank and check valve to relieve the pressure caused by therm al expansion.
Contact your local dealer for assistance. - Old-BiscuitExplorer III
RELIEF VALVE
will develop.
And there you have it........
Reinforced what has been posted and supplied by the RV Water Heater MFGS...BOTH of them
An Air Pocket to control pressure increases and use of an accumulator tank if needed
Amazing :S - John_JoeyExplorer
Old-Biscuit wrote:
Have been in campgrounds that WARNED of HIGH Pressure
Have been in campgrounds that had as HIGH as 120 PSI in system...
X2
I've also seen those cheap water pressure regulator with a dial slowly allow the pressure to build up while I was not paying attention. The picture Lawrosa posted is the absolute cheapest, and wasn't nowhere as expensive as the one I had in the beginning. I can only guess that one posted is a POS.
Only real good solution I found was a whole house brass regulator. Last one I had I got at a big box store for $45. - Dave_H_MExplorer IISo grumpy, where are you gonna put it now?
- grumpy2dayExplorerI think I will continue to put the pressure regulator where I have always put it. At the cg faucet.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
