I normally have my inverter/charger off. When I would run the generator, I would put the inverter in the "Charge only" mode. This way the inverter will not pick up the load as the generator output sags on each starting of the A/C compressor.
I have user adjustable set points on my inverter via the remote control (I Have a R-6 (or something) remote and M1215 modified sign vave inverter).
By pushing the left two buttons and holding them, I can make adjustments to the inverter in the second screen. I can change the drop out voltage to only 85 volts if I want to.
You can normally set the amperage to 5 amps to 30 amps in 5 amp steps. So if the inverter input is over the set amperage, in my RV, the charger slows it's charge rate while the amperage is close to the set point. However some inverters like the Trace SW 25 12 has the ability to sync with the generator's wave form, add amperage to the output, and then take battery power to meet the output needs. So I am not sure what your sine wave inverter will do to help the load.
Fred.
