Dave_H_M's avatar
Dave_H_M
Explorer II
Feb 03, 2018
Puck Style 20 to 15 A 120 Volt
I have a separate 15A 120 power cord that i use to run the heater separate from the camper 30 amp service.
On my last trip, On two occasions the park's 120 power cord receptacle was the 20 amp type (the one with the blade that runs off perpendicular to the hot blade. So my 15 amp plug will not fit in there. i been searching for a puck style adapter that will let me adapt my 15 amp plug to the 20 amp receptacle. i probably am not using the right words on my search or something.
I would appreciate it if anyone has a quick link to one and would post it. Thanks in advance.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I have seen outlets that are 20 amp only I know of no own who makes a PUck but a "Dog bone" is easy
    Get a standard 15/20 amp Outlet (Extension cord end) and a 20 amp plug
    usign 10 or 12 ga wire (12 is codem 10 is heavier duty, I like to go big) you need about 6 to 12 inches is all.
    Connect Black wire to the copper serews
    White to the Silvery screws
    Green to green
    and seal the cord to the outlet and plug where it enters (GOOP works well)
    Job done.
  • I would not use a puck sty;e adapter. They will overheat and could burn.
  • NEMA 5-20R typically has a 'T' slot for the neutral and will fit either plug. If the Hot is turned it is a 6 series for 250 volts. Put your meter on it.
    Otherwise look for a short appliance cord rated 20 amps as it should have the turned neutral plug and a 'T' slot receptacle for your extension cord.
  • enblethen wrote:
    A standard 20 amp NEMA 5-20R should accept a 15 amp 5-15P without any problem
    A 6-20R is an opposite configuration and is 250 volt.
    They are the same size.
    Where was this found?
    X2 sounds like the park used a 250 volt outlet.
  • A standard 20 amp NEMA 5-20R should accept a 15 amp 5-15P without any problem
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
