Tvov wrote:
Rotate your fuel cans.  I have a few 5 gallons gas cans.  Fill them up, use them for mowers, small engines, etc and if there is any left after a month or so I empty them into my truck.  Then refill the cans.
Rotating gasohol out of jugs periodically seems kinda logical vs. a interweb "hack"...
But
If you have a small engine or genny that absolutely has to start and run when needed you can store it with synthetic alkylate fuel - long shelf life - it will start - then use pump gasohol (it's not gasoline if it has ethanol in it - see the MSDS'sz) - then drain and shut the unit down with alkylate fuel in the system again...
