  • I used one of those while working in Africa for coffee maker and my blender and other American accessories I took there. Worked great as long as the appliance didn't wasn't picky about 50hz.
  • DrewE's avatar
    DrewE
    Explorer III
    pianotuna wrote:
    Hi Mex,
    I considered something similar when I was trying to find an autoformer.
    I suppose two of them back to back could be used as an isolation transformer.
    These are almost certainly autotransformers internally, so two back-to-back would not provide isolation. Since this is a voltage stabilizer with a specified .5 second response time, I'm guessing it is a mechanical servo-controlled variable autotransformer, but I could be wrong there; it might use some sort of solid-state electronic switching or something.
    The power rating seems rather optimistic, especially given that the manual says you should buy one rated for at least twice the power that your load requires. "Important: Remember to leave at least a 100% slack for the voltage converter transformer. Televisions, Heating appliances, Laser printers, Halogen & fluorescent bulbs and power tools spike when you turn them on. For these products you need to buy a voltage converter transformer that is at least 3-4 times the items capacity."
    Pyle is not known as being a supplier of top-shelf gear. The price of the deal on WOOT does seem fairly decent compared to what these go for elsewhere, if you're interested in low-end stuff of possibly questionable build quality.
  • There are lots of cheap and easy voltage transformers. The problem comes when you want to run devices that are affected by 50hz vs 60hz (not all are).
    If you want a true global vehicle, get yourself a large enough battery charger that will accept either power supply and then run everything off an inverter. This will allow you to supply clean power of the correct voltage and hertz.
  • That's an impressive looking device. Perfect for someone equipping their global expedition vehicle for exploring over seas.
  • Hi Mex,
Having RV issues? Connect with others who have been in your shoes.24,378 PostsLatest Activity: Apr 12, 2026
