CA_Traveler
Oct 02, 2021Explorer III
My first thought is your tech is clueless, find someone experienced. Rack and pinion suggests electric. Hydraulic would have 2 hoses per cylinder - 2 for a jack and 2 for each hydraulic ram. He should be able to easily determine what you have.
The thunks are likely a solenoid or heavy relay. Your switches cannot handle the very power draw so they activate the solenoid which has a second heavy wire from the battery.
I would start with a digital voltmeter connected to a clean frame ground (not a wire) to the battery + cable. What is the voltage when the clunk occurs? Continue downstream and you should have close to 0V on the negative wire and 11-12V on the positive wire to the motor.
I'm also wondering if the batteries are wired correctly, one or more reversed. And don't assume new batteries haven't failed, it happens.
