ChuckSteed
Oct 05, 2021Explorer
It would help if you knew your RV and what it does or doesn’t have for slide motion and leveling motion.. this way I could precisely tell you where to look and what to check..
If hydrauilc slide out the THUNK noisier you are hearing is the dual polarity solenoid mo7nted on the hyd pump motor.
That indicates you are getting power to solenoid but not enough to run the pump motor..
Here is a l8nk to tell you how to test the solenoid and pump motor.
These should be located inside an access door on one of the sides and you would,not be trying to gain access via underneath
https://lci-support-doc.s3.amazonaws.com/technical-information-sheets/slideouts/ccd_0001894.pdf
There is also,a manual,override for the slide and leveling system if this is hydraulic
Need specifics as to what your systems are or aren’t to accurately help you an6 further
