Ductape's avatar
Ductape
PV panel selection? (long)
Hello, all. I’m looking for some feedback on PV panels before embarking on the next upgrade to our electrical system.
To establish the background, we will be mostly boondocking, and moving frequently, so the panels will be flat on the roof. Batteries are 600 ah AGM. I anticipate using 50-100 ah per day depending on the weather. If the batteries need some feeding we always have the gen and a PD 9280 converter to stuff some amps in. Performance in partial shade is important for us, we don’t want to select campsites without trees all the time. I would prefer to supplement with a little generator from time to time if needed.
I’m thinking in terms of ~400-600w for now, with the option to upgrade later if we swap to a residential fridge or ...
Q1: brands to include / exclude? I am the type to buy a Honda, so I don’t mind paying for quality, so long as it’s not just branding. I want reliability. Kyocera is uppermost in my list right now.
Q2: Poly / Mono? I have read a number of times the poly respond better with partial shading. This gets complicated in my mind because I can fit a smaller mono panel between the roof obstacles at equivalent wattage… therefore the mono may get full sun more hours per day by virtue of the smaller footprint.
Q3: panel size. For instance I could go with two KU265-6MCA or four KD 140SX-UFBS. The second scenario the panels cost about double (at least at the prices I was looking at today). Downside is the 265w panels are slightly longer in the longest dimension, and will be partially shaded a bit longer by the A/C units. And if I want to expand later, I will have room for more of the 140’s. Not so with the 265, I would have to mismatch panels and maybe do a second controller. I am also thinking the four panels will be somewhat more shade tolerant (more bypass diodes in total). I’m planning to run the array in series.
Your comments much appreciated.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 14, 2025
