Almot wrote:
2oldman wrote:
jayw900 wrote:
I have a 100 watt, 21 ish volt panel and a pwm controller right now. I'd like to get a 345 watt, 39ish volt panel and mppt controller but they can't happen at the same time.
They can, if ...
a) the panels' amperage is about the same
b) you wire them in series
I think he meant the financial issue. Big panel now, $$$ MPPT next year.
Typical big panel will have amps very different from his existing 100W. And if it's not very common - like that 6A*55V in the link - then it likely won't be cheap or readily available in the area.
This is pretty much the idea but reading through it does sound like I should just wait till I can do both
