jayw900's avatar
jayw900
PV upgrade decision
Right to the point: should I upgrade to a bigger panel or to an mppt controller?
More info for those that take the time to read:
I have a 100 watt, 21 ish volt panel and a pwm controller right now. I'd like to get a 345 watt, 39ish volt panel and mppt controller but they can't happen at the same time. Would it be better to go with the bigger panel knowing I'll lose out on some power right now or get an mppt controller to try and squeeze any extra out of my current 100 watt?
Right now I'm thinking the larger panel would be better even with the losses but want to make sure I'm not missing anything.
  • Where exactly are you going to find a 345 watt panel? I haven't seen any bigger than 325. I'd love to get my hands on some if they exist.
    If the controller will handle the voltage of the big panel I would get that first. It would still probably be around a 60% increase from what you have now. The Voc of a panel will increase by as much as 25% when it's really cold. Make sure your current controller can handle that voltage.
    They can, if ...
    a) the panels' amperage is about the same
    b) you wire them in series
  • As SMK said it depends on whether the existing charge controller can tolerate the higher voltage of the new panel.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
