Learjet
Jul 06, 2015Explorer
you can easly find it online...but here are the cliff notes ;)
Fan Speed
Press the On/Off Mode button until the fan green LED is lit. The
LCD will show “Lo” (Low), “Hi” (High) or “Au” (Auto). Press the “+” or
“?” button to select the desired fan speed. See “Special Features”
on page 11 for more information on Auto Fan.
page 11:
Special Features
Auto Fan
When auto fan is selected the fan speed will vary depending on the
difference between the temperature set-point and the room temperature.
In auto fan the compressor and fan cycle On and Off with the
thermostat.
When the difference is:
>5º The fan operates on HIGH
<4º The fan operates on LOW
What they don't tell you is... the compressor will still run while the fan changes speed...also you may have it changing back and forth until the temp is reached.
Fan Speed
page 11:
Special Features
Auto Fan
thermostat.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
