MEXICOWANDERER's avatar
Aug 15, 2014
QUESTION Expected Lifespan Of a Power Supply ?
Let's say A 300-watt power supply is used. But only a 280 watt constant load was applied to it, in this case of course LED's.
Any guesses as to lifespan? in hours or years? Max ambient temp of 90F.
The answer of course can be transposed to any switching power supply of this type for other loads. RV converters seem to go years and years without glowing in the dark.
Not To Worry Time?
  • This system is going to light a small supermarket about the same size as a large 7-11.
    Hours 0600 to 2200 hours every day.
    I guess I had better plan on blowing some cool air to the unit with a 15 watt 120Vac aux fan.
    If the power supply should fail, business in the store stops dead. We'll get a backup down the road sometime. Plans are to mount the PS not in the ceiling but run a mains with distribution branches.
    Prospect is for ONE EIGHTH the power consumption of ice-age model existing fluorescent lighting. How can those fluorescents emit GRAY lighting? It's pathetic.
  • My guess would be "depends on the duty cycle design." If the PS is designed to deliver 300W continuous it should last fairly long. If it is designed to handle 300W "peak" and something less than that continuous, it probably won't last very long. You say "only" 280W but that is running at 93% of rated capacity, so may as well be full load.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
