BFL13
Apr 20, 2017Explorer II
OK needs more research. The 8300 is the power centre which apparently?? comes with a Parallax 4400 converter. That converter has an optional plug in module you can get that has the TempAssure. (uses a long wire out to the battery where the temp sensor on the end of the wire goes. They are calling that module the "upgrade"
ISTR it needs that module or else it is 13.6v only? Get back to you on that. Yes--with the TC it will start off at 14.1 nominal(adjusted for temp) every time and drop to 13.6 nominal
https://bestconverter.3dcartstores.com/assets/images/Parallax/4400/paramodemanual.pdf
I had a 4455TC a few years ago and it worked well till I fried it somehow, changing things around in my rig.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
