Dr Quick wrote:
I believe that LED lights are polarity sensitive, as they are not a bulb, but a diode. They must be connected positive to positive.
OP is talking a 120V AC LED bulb.
Granted LEDs are "polarity" sensitive, but in the case of 120V AC it DOES NOT MATTER.
The reason why is the LEDs act like a diode and only conduct ONE WAY, AC ALTERNATES "polarity" so a LED would conduct no matter how you hook it up.
However, properly made 120V LEDS use ADDITIONAL circuity in the form of a full wave diode rectifier, small filter capacitor and a couple of resistors to feed the LEDs DC voltage..
Advanced 120V LEDs take that one step forward by adding in a LED DRIVER circuit which regulates the current the LED gets.
Any case the result is a 120V LED does not care as to "polarity" as in 120V Hot/neutral.
