Hondavalk wrote:
I'm sorry but seeing how you thought it was ok to switch the neutral and attached the ground wire to the plastic J box, I would sincerely suggest you hire an electrician for future wiring needs. Not trying to be insulting, just safe.
If there was a chance of a wire to a lite being damaged, which one would choose, the white or the black ?
That's why I chose to break the white instead of the black.
Question,....if code let you break either wire, I'd bet you'd be ok w/ breaking the white wire.
Myself ?? I see nothing bad about the black wire to a lite being hot all the time. Isn't that what happens when the lite is on all the time ?? I know,..I've always had trouble using too much common sense.
