brulaz
May 26, 2014Explorer
bdpreece wrote:
To remove the light from the ceiling you just pull the fixture straight down and the spring arms will fold up. Actually to change the bulb if you push up on the glass lens and turn it counter clockwise most of the covers will come off without removing the light from the ceiling. when installing the new bulb do not touch it with your bare hands as the oil in your skin will cause the bulb to burn out earlier. Be careful not to drop the glass cover as they are hard to come by if you break it.
I replaced all my bulbs with LEDS G4 2.2W 190-Lumen 12 SMD 5050 LED Reading Light White/Warm White Bulb Lamp DC12V. got them on ebay for $1.50 each with free shipping.
Same issue here.
Hmmmm, mine are already LEDs. But the lens looks like the picture above. Don't recall seeing the springs.
When I pull on the fixture it comes down about 1/4" and then sticks. I hesitate to pull harder ... but the springs should collapse if I do?
When I try to rotate the lens, the whole assembly turns, so I need to pull the fixture out and get a better grip on it I guess.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
