theoldwizard1
Nov 25, 2018Explorer II
mrad wrote:
So two 6V GC would be better than my two 12V deep cycles? I was hoping to not spend a lot, but my RV battery will need to be replace so I guess I could put the CG batteries in the TT next spring, right?
It is highly unlikely that your two Group 24 batteries are TRUE deep cycle batteries. They are likely marine/RV "dual purpose" and are therefore a COMPROMISE ! The only commonly available true deep discharge batteries are 6V golf cart batteries. They are designed to specifically handle more charge/discharge cycles. They can tolerate a deeper discharge.
mrad wrote:I am assuming when you are running the generator you are also running the battery charger.
What a 12V DC fan? Would I then have issues when running off gen power?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
