Chris_Bryant
Aug 05, 2016Explorer II
The only difference is the V is taller than the IV, so if the water connection doesn't have a couple of inches of vertical play, you will need an extension of some sort- a plastic 1/2"x1/2" male nipple plus a short faucet connector with 1/2" swivel on each end will do the trick.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
