rjsurfer's avatar
rjsurfer
Question on solar controller hook up?
I finished up most of my solar install today and I noticed an issue when hooking up the solar controller to the batteries.
I'm using an A/B Both switch to control what bank or banks I want to run.
Prior to the solar controller I had only two things tied to the output of the battery switch, my inverter and the connection to the converter in the distribution panel. Which worked fine.
When I went to connect the output or battery connection of the solar controller to the A/B switches output terminal, out of habit I just lightly touched the wire to the terminal and noticed a spark nothing big but as spark none the less. At the time I was running on the generator so I'm assuming the voltage was from the converters output. Sure enough when I measured the voltage it was 14.7 volts DC which is the output voltage of the converter/charger. I'm guessing I shouldn't have made the connection with the converter being powered up.
So as a sanity check before I make the connection permanent I want to make sure I'm not doing something wrong. I'm assuming that the solar controller is made to accept the converters output when running shore power. And the small spark was just normal :-)
Ron W.
  • MrWizard wrote:
    traveler
    i think that depends on the particular controller
    my blue sky will shut down
    with many less expense controllers
    the danger comes .. because users install and hookup in the day LIGHT hours
    panels could be a full Voltage potential before being connected
    many controllers come with this hookup warning
    but the instructions never seem to say what happens if the fuse blows
    but assuming it is properly fused..then the controller is already "malfunctioned" or the fuse would not be blown
    I was thinking if something bad happened at the battery end.
  • traveler
  • CA Traveler wrote:
    OK, If the controller doesn't like a panel only connection what happens if the fuse to the battery blows?
    That stopped the controller-battery pos wire from becoming the fuse and melting at the controller terminal, so the controller is toast anyway?
    The OP is ok at 14.8v when connecting the 12/24 controller (no array connected yet) ISTR if it sees under 18v it will decide it is on a 12v battery and if over 18v it will decide it is on a 24v battery. so at 15v it will go 12v as desired.
  • OK, If the controller doesn't like a panel only connection what happens if the fuse to the battery blows?
  • Thanks for the feedback, looks like I was doing everything OK. Will go back tomorrow and reconnect everything in the proper order with shore power off.
    Ron W.
  • the controller will "IGNORE" ? the converter voltage applied at the output side from the batteries
    it will NOT accept it on the Input side
    the correct procedure for hook up
    1. batteries only, no converter no generator no shore
    2. connect controller to the batteries first, controller needs to sense battery system voltage before panels are connected
    3. connect solar panels to batteries
    DO not get these steps backwards..some controllers will be damaged if connected to solar panels and there are no batteries to accept power output
    4. you can now use any additional charging you want..shore, generator, driving, external battery charger
  • Hi,
    The output of the solar controller should be in the 13.2 to 13.8 volt range. However if it is a PWM controller, it might be as high as 21 volts when not connected to the battery.
    Once you connect the solar controller to the output of the battery, then the controller output will be slightly higher than the battery voltage before making the connection, or if over 13.8 volts (or the shut off voltage for your controller) it might not read any different than the battery voltage.
    As for the spark, if the polarity was wrong, you probably tripped a fuse, or everything is OK if the polarity is right. A tiny spark is acceptable.
    Good luck!
    Fred.
  • Double check, then triple check the polarity and make the battery connection.
    Check the instructions but I believe you should connect the battery side first then connect the panels to the controller. Controller may have issues if you disconnect the battery before you disconnect the panels. May need to be careful of using the switch OFF position but again check the instructions.
  • RoyB's avatar
    RoyB
    Explorer II
    I haven't got to do any installing yet but I think there is some DIODES involved to keep certain things out of the solar picture... Sounds like theleg beween the solar controller and the on-board converter might be a good spot for a DIODE...
    Ro Ken
  • If your controller is like mine, it gets its power from the battery bank. Just connecting it could cause a small spark.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
