boogie_4wheel
Nov 24, 2015Explorer
The heat pads cannot be used on a double wall. As Dave said, the tanks are supposed to be partially full to help absorb the amount of heat that they give off.
I have twin 40g holding tanks and bought the 120VAC pads. They did a great job on my exposed tanks in -20*F (trailer was skirted with OSB). If you were to travel, then the combo AC/DC pads could be a benefit, but heating elements work via electrical current and would have the ability to pull the battery(s) down quickly.
They would be powered separately, you would turn on/plug in the AC plug or flip on the DC switch; they will not automatically switch over.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
