dave17352
Nov 24, 2015Explorer II
Ok so you have fully enclosed heated holding tanks. I would have to say not double wall tanks. My heating pads are twelve volt and yes they will run the batteries down in no time. But the 12 volt is supplied by your converter. So as long as you have electricity you are fine. No need to switch over because on+ce the converter quits working it will simply draw down your batteries. The heating pads work great just don't run them dry. JMHO
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
