mr_andyj
Nov 02, 2020Explorer
honestly, i have heard that you should "exercise" the generator head by running it, but I cannot give a reason for this other than maybe it helps blow out some dust before it accumulates too much. The generator head is just an electric motor in reverse. Do you "exercise" your home ceiling fans during the winter? No. Do you pull out your electric appliances and exercise them monthly? No, that would be really dumb. I do not know what component on the generator head would need to be exercised, so cannot say for sure, do not exercise it, but I have never exercised some gens and never ever had any issues.
Does a gas motor need to be exercised? No. Motors can sit for years and years and still function exactly the same. Metal parts will not age, at best change the oil.
What will age is any gas left in the system (carb or fuel tank). In all the times I have taken apart I never see any seals that need to be kept wet with oil either, most seals are paper. None of my motors need to be run.
Running a motor will run clean gas through the carb and keep it clean just from use. That is about all I see that running would help with.
If you can protect the carb for storage (choose your method) then that is it. Done.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
