handsome51
Nov 02, 2020Explorer
Solving the gas problem is easy. I go to my local small airport in town and fill me up a couple of gas cans with av gas. Then when I get home I take my other gas cans and fill them half full with av gas. Then go to the gas station and fill the rest with unleaded gas. I run this in my generators. My chain saw engine is a two cycle. So I use pure av gas in it. You have to go 50/50 on a 4 cycle engine. But I never have a problem with the gas going bad. Years ago I had problems with my 140hp outboard carbs jets getting plugged from sitting from labor day to easter. It didn't make any difference if you ran the gas out of it our used a additive. I started keeping a 6 gallon outboard tank filled with av gas. And I would run the engine on that tank when the motor would be sitting for a while. Never had to pull the carbs again to unstop a jet. If you run your generator on the 50/50 mix.You won't have a problem with the generator when winter is over
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
