Chum_lee
Nov 14, 2020Explorer
mr_andyj wrote:
AV gas...
Jet fuel is half kerosine, this keeps the fuel from freezing at 35 below, so is it the kerosine that is the key component in the AV gas or the gas itself? does AV gas have kerosine?
Can you just mix half with kerosine?
I think you are confusing AVGAS (or 100LL) with jet fuel (Jet A or JP-4). AVGAS is for spark ignited piston powered aircraft where Jet A/JP-4 is for turbine engines (jets) and has high kerosene content. AVGAS generally has little/no kerosene content because kerosene has a very low octane rating. AVGAS is much more highly refined than automotive gasoline. AVGAS has very low olefinic content and little/no ethanol. Olefins are straight/branched chain hydrocarbons with one or more double bonds between the carbon atoms. Although they have high octane ratings, they are very reactive, unstable, and, over time, tend to form gums/varnish in the fuel and what it touches. AVGAS generally has a much higher aromatic (benzene, toluene, xylene) content and is very stable over long periods of time. Aromatics have very high octane ratings. That's why they are used.
Unless you want your spark ignited piston engine(s) to knock like crazy, (and potentially destroy themselves) do not add kerosene to your spark ignited piston engine fuel. Diesel is a different story.
Chum lee
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
