Chum_lee
Jan 25, 2016Explorer
Look at the gauge of the pigtail wire that comes out of your RV. What gauge is it? Mine is 10 gauge and I have a 30 amp service/genny on my RV. The pigtail is about 20 feet long. I also have a 25 foot extension cord which is also 10 gauge which I rarely use. (three conductor) I would not use any further extension cords unless all the extension cords were 8 gauge or less. (larger) You have NO CONTROL over the line voltage at the panel. It may be 125 volts on a slow day, it may be 110 volts (or less) when the electric company is working hard on a hot summer day. W = V X A. Watts equal volts times amps. If the voltage goes down, for whatever reason, the amps must go up to maintain the system. Circuit breakers and wire are sized based on amps. That doesn't even take into consideration derating for LRA (Locked Rotor Amps) or LCL. (Long Continuous Loads)
Is it worth it to save a few bucks on the installation if you have to go out and reset a flipped breaker every other day? Or worse yet, replace a burned up motor, or even worse yet, repair fire damage? I think not! Your choice.
Chum lee
Chum lee
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
