- NinerBikesExplorer
enblethen wrote:
Number eight should work OK.
I would suggest getting a digital plug in volt meter to keep an eye on voltage. Using air conditioning along with microwave could drop voltage down to minimum levels.
I would check voltage at the panel where you are connecting new circuit. make sure it is in the 120+ range. If much below 120, you should think about the #6 wire.
/\This... or just do it once, labor is expensive, and just buy and pull 6 gauge copper. Not worth the risk of voltage drop on expensive equipment like A/Cs or microwaves. Low voltage kills them quickly. - Number eight should work OK.
I would check voltage at the panel where you are connecting new circuit. make sure it is in the 120+ range. If much below 120, you should think about the #6 wire. - Ron3rdExplorer III
gbopp wrote:
You may want to Google a Voltage Drop Calculator. I just checked one and it recommended #6 wire for 30 amps @100 feet.
#6 wire is the minimum.
OK, so if I only need to go 60 ft, can I use #8? - n7bsnExplorerThe "charts" say 8 gauge copper.
- gboppExplorerYou may want to Google a Voltage Drop Calculator. I just checked one and it recommended #6 wire for 30 amps @100 feet.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 16, 2026
