pianotuna
Feb 01, 2015Nomad III
Hi,
Is this unit for weekend use? How big is the battery bank? What do you plan to power with the 1000 watt inverter?
There is no reason what you suggest will not work, however, be aware that a 1000 watt inverter running flat out will draw about 100 amps. That can flatten a battery bank pdq.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
