NinerBikes
May 02, 2014Explorer
mena661 wrote:MEXICOWANDERER wrote:Trojan has float specs but I only meet them in the spring and fall for the most part. I do have a HF floater with a diode for the really hot stuff but an auto temp comp float would be awesome. Looking forward to getting some solar so this can be accomplished correctly.
Automatic means thermistor. Means warping the control circuitry. Have you determined what "float" means amperage wise to your own battery bank Mena? Are not those battery maintenance gizmos temperature reactive?NinerBikes wrote:I live in the high desert near Edwards AFB. I camp in the cool weather but charging and stuff is done at home in the heat. I do need to come up with something because the Iota shuts off at much over 100 so floating with it is a no go then. No interest in going that far with adding electronics to my chargers. My tweak gene only goes so far with this RVing stuff. :) I would rather tweak my computer! Besides my next project is solar and I have some things to do first to prep for that.
Where do you store your batteries that it's 43C in the 661 area code? I thought you go to the beach, with onshore flows in your Class A?
I thought you had it handled with solar too, for topping off purposes. 450 watts, three 150 watt 22 V panels and a PWM controller of some sort, with temp sensing, on your roof.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
