azrving's avatar
azrving
Top charge Mega Watt
This gp 27 was used for a trolling motor and I used it in our TT last winter. It was charged at 14.4 and would go to float but had poor performance. I just charged it with my show maker which I know is not a good choice but anyway the sg gravity wouldn't come up after many hours at 14.6
I started at 12.58 volts. RV monitors would consider it fully charged and according to a stste of charge chart it would consider it about 95%.
But, the SG was only 1.248
I started charging it with a Mega Watt 12 volt 36 amp power supply. My gauge only goes to 30 amps so I kept adjusting it up as the amps kept dropping off.
v-----amps-----time
12.58--30------12:45
13.90--25------12:55
14.01--30------1:00
14.12--25------1:04
14.37--30------1:08
14.83--25------1:13
14:91--30------1:17
15.32--25------1:25
pot is all the way up, pretty fast gassing and some odor so I started backing off.
15.00--13------1:28
14:80--7-------1:36
SG had come up to just over 1.250 I have a cheap hydrometer. New one is on it's way.
14.80----3-----left it at this for a while as it was bubbling pretty fast and odor increased
15.0-----2-----2:15 gassing has slowed, letting it charge at 15.0 and 2 amps
My first observation is that my true deep cycle 6 volt is much more tolerant of 15.5 than this deep/marine as it barely bubbles with just a slight odor. The worse temp increase I've seen was 8 degrees.
The SG was consistent from cell to cell so it would seem a true equalize isn't the issue. I'll let it go and see how long it takes to get the SG up.
  • OH MY GOD THE GARAGE IS ON FIRE!!!!!!
    Naah just joking. It's at 15.5 4 amps with a pretty good bubble going on, some odor but not terrible. The SG is up to about 1.262 or so.
  • BFL needed 16V and then some on occasion for his to get up to baseline SG. Don't be afraid to bubble those bad boys.
  • mena661 wrote:
    Let it gas, let it gas, lleeeeettttt it gas!!!!!!! :)
    lol.
    It was still sitting at 15 v, decent bubbling and just a slight odor near the battery.
    I have it at full throttle now, 15.48 and 5 amps.
  • All that fun is why I no longer use 27DC batts, but 6s. Like pulling teeth to get the SG up on those 27s.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
