MEXICOWANDERER's avatar
Apr 26, 2014
QUESTIONS re: MEGA-WATT 33-AMP POWER SUPPLY
This critter can be found on eBay. It is a switching type power supply.
Supposed to have an ultimate amperage potential of 33, voltage adjustment of 10, to 15, and work fine as a long term battery CHARGER as well as a power supply. The unit has good reviews.
I read all the time on this forum about folks PARALLELING their switch type "converters" to increase total charging ampacity.
But the -supplier- of this switched unit says to not connect more than one to a battery or they will "burn out".
I simply do not have the experience with PWM switch controlled power supplies to appreciate -why- car battery chargers yawn at being connected in parallel to a battery or bank and yet this one would "burn out".
Would not an appropriate electrolytic capacitor serve to suppress the amplitude of whatever ripple the PWM frequency operates at?
Only experience can yield an answer to this. I sure would like to travel with a 66-ampere charge rate in a small toad.
Having RV issues? Connect with others who have been in your shoes.24,326 PostsLatest Activity: Oct 23, 2025
