Cummins12V98
Jan 27, 2019Explorer III
rhagfo wrote:Tom_M wrote:
This photo shows the difference between self-tapping and self-drilling screws. There is no way that you will be able to drive a self tapping screw into structural steel without drilling a pilot hole first.
Boy this post is up to 5 pages, and REALLY, this is being WAY over thought!
I have done the seal the bottom of our 5er with Coroplast, used hex head self DRILLING screws, and galvanized steel building studs from HD for support.
I believe I used #10 screws, the socket I used on the driver I filed down so it was all gripping surface. All sockets have a small rounded surface to make it easier to get the head into the socket, by filing that away I didn't slip off the hex head. I also used fender washers and just snugged up to the coroplast so as not to crush it. The self drilling went into the frame rails without too much effort.
I will try to send pictures later.
I used sheet coroplast, as my shocks are mounted inboard of the frame and I needed to box around them. I ordered black at about $11 a sheet and used ten sheets to do our 32' 5er (about 23' of frame).
OP, here is your VISUAL answer! Do as mentioned here and you will have ZERO issues.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
